Yes its all the hidden bits that really eat up the time, I mean look how long it has taken to do the soft top box, and I don't think I'm all that slow at this, I guess an experienced Mercedes metal man would have knocked it out a bit quicker, but I cant imagine it would have made that much difference. I wish I had bought a metal folder early on in the job but I kept making do and it is probably a bit late in the day for me to get any real value out of one now.
True to form the Mercedes has thrown me another curveball. I was struggling a bit on Saturday with the rear fender. I was getting the hump with it and felt I needed another pair of eyes and hands, Ronni is very good at this sort of thing so she and I had a couple of hours on it this afternoon. It is amazing what fresh perspective and a skilled wife can do....
It was all going so well, I was just about to put a tack on the inner fender when I thought I ought to try the rocker moulding on before I do anything final, seems that either at some point in the mid 60's Mercedes decided to shorten the distance between the door and the wheel well by 5mm, or I somehow made this car a bit smaller.
My original fender was 195mm between the door and the wheelarch, the new one is 190mm. Seems a small amount but it really screws things up and now the rocker moulding is that bit too long. I must be getting all zen with this car because rather than throwing a tantrum I just kind of smiled and carried on....I'll have to cut the rocker moulding down and weld the return back on I guess.
I looked on the SLS website and the replacement rocker moulding is listed for 1965 on, I wonder if some alteration was made to the shape of the wheel arch then to give a little more clearance at the front of the tire.
Anyway showing true grit as normal I pressed on, once the inner fender was aligned I got a couple of tacks into place on the front and a couple of spot welds on the rear, removed the rear wing again and pressed 'The Chief' into action.....
