I'm having difficulty finding a part I need. The Mercedes Restoration Center parts dept. says it's no longer available. I find that hard to believe. My car is a USA version 280SL 1970 (manufactured in Sept. 1969) Here's the info on the unit I can make out. VD 9.69, then 6 24v 3w, then 17 +-3 deg c, then 20 deg c, then 11/20/01.
If you can help, please let me know. There may be substitute parts that work just as perfectly as the OEM. The MB Restoration Center is obviously restoring w113s, so they are using "something" if indeed this part is unavailable.
