Hmm. I just had a sort-of similar experience with a 250. The timing chain broke at 4000 rpm. It destroyed the cam, two towers, and damaged all the sprockets, plus the oil pump/tach drive. So, replaced all the gears, chain, and tensioner to the tune of $4000. A week later, the car was back with a rod knock, and I am now finishing up installing a rebuilt short block.
Hope to spare you this frustration. You might get very lucky, but the odds are that the bottom end has sustained damage that will show up sooner rather than later.
