Author Topic: Stud bolt broken - chrome trim heating levers  (Read 3314 times)
sftp600
« on: November 22, 2014, 18:56:35 »
Hello forum,
After having revised my whole heating system (the radiator was leaking), I am currently reassembling the different parts.
Unfortunately I broke one stud bolt from the chrome trim of the heating levers, because I tightenend it too much...  :-\
Do you have any idea how i can fix the bolt?
Thank you very much for any help...
Regards
Manuel
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
Re: Stud bolt broken - chrome trim heating levers
« Reply #1 on: November 22, 2014, 21:32:24 »
That's going to be tricky because it is so small.  A good re-chrome shop could cut it off, weld on a new one and re-chrome the part.  Apart from that, I think you're faced with trying to purchase a new one or using an adhesive.
« Reply #2 on: November 22, 2014, 21:50:25 »
You may get away using some Q Bond as it does not need to be really tightened down, only held firmly against the dash.  But like Ray said being so small will present a problem.  Only other alternative is to see if a jeweller can silver smith it back together.
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
andyburns
« Reply #3 on: November 22, 2014, 22:16:30 »
I had the same problem and my good friend Rodger fixed it perfectly.  There is a small raised boss which has just enough meat to drill into and tap out enough threads to take a replacement stud.  You have to be incredibly careful to not drill all the way through and need specialist equipment.  But still probably cheaper than a replacement.
1963 230sl
1967 250s w108
1969 BMW 2002
2007 Mitsubishi i car
« Reply #4 on: November 23, 2014, 23:59:09 »
I have done the "Andy" fix also. worked out fine. I don't think that you can weld a stud on this part, it is a zinc casting most likely.
