Author Topic: The plug goes in the the top, right?  (Read 3749 times)
ausabbob
« on: November 26, 2014, 01:27:29 »
I am in the process of replacing the rubber weatherstrip/seals for the convertible top windows on my 67 230 sl. I obtained OE pillar seals as well as seals for the roof rails for each window. The window seals came marked left and right (which had to do with the length of each arm, otherwise they were identical), but the A pillar seals had no such markings and were identical. As they will be inserted as mirror images it would be no problem if they were truly identical which they were, with one exception. Each had a plug in one end. If I put them on as is, one side would have the plug at the bottom of the seal and the other would have the plug at the top. After contemplating this for several hours and without instructions from anywhere I could find, including this site, I came to the conclusion that the plugs are removable and could be put in either end of the seal. I found a narrow wooden dowel I could slip (with some Teflon lubricant) down the seal from the open end and pop out the plug(s). Cool! Now my problem became "why did the Germans put this plug there and what was its purpose?". The conclusion I came to is that the plug goes in the top of the seal and prevents the open center of the seal from becoming a column of water when it rains. Is this correct or did I miss another less obvious conclusion?
And while I'm on this matter, its obvious the seals for the windows need to be cut so the top can be retracted, yet the seals for each side come in one piece with a sharp angle corresponding to the angle between the top of the window and its back side. How best to cut the seals to minimize air flow at speed? My thought is to put them on in one piece on each side and then find a razor sharp knife to cut them at the separations of the rails of the top. Is this right or is  :-\there a better way?
UJJ
  • USA, CA, Grass Valley
Re: The plug goes in the the top, right?
« Reply #1 on: November 26, 2014, 14:07:03 »
You are perfectly right with the A Pillar seals. I did the same thing. Took the plug out of one and replaced it back in at the opposit end. No water will get into these seals that way.
I saw many aftermarket seals which do not have this plug, nor do they have the "felt like" surface where the window slides against it.
Cannot help you with your soft top seal question. I had my softtop replaced by SL-Tech Gernold Nisius. His canvas replacement work includes restauration of the frame and all seals. Perhaps give him a call?
Happy THanksgiving, Urban
Urban Janssen
Grass Valley, CA
1968 280 SL - 4speed manual
173 anthracite grey
mmizesko
  • USA, OH, New Albany
« Reply #2 on: November 26, 2014, 14:27:26 »
That is what Joe Alexander did with my new seals. Just be careful of the angle.
Mike Mizesko
Columbus, OH
1970 280SL 291H Dark Olive
ausabbob
« Reply #3 on: November 29, 2014, 13:26:32 »
Thanks for the confirmation. I bit the bullet and cut the window seals with a sharp knife, knowing that a screw-up would be expensive. So far so good, everything went uneventfully and the new seals work well and have cut down noticeably on wind noise.
jerrycastillo
« Reply #4 on: April 20, 2015, 21:58:47 »
Hello Cameron,
Do you have a picture of the cut in the seals that go from the top  to the rear pillar? Also,do you have pictures of how you fastened the seals to the pillars? Thank you.
Gerardo
