Author Topic: 230sl fuel problems  (Read 2784 times)
pagoda113
  • United Kingdom, England, Surrey
230sl fuel problems
« on: December 05, 2014, 18:15:02 »
Have 230sl 1965 and not fireing on all cylinders. Have done compression test and is ok. Injectors are also ok and changed the fuel filter. What is happening on cylinders 1, 2, 3 there is plenty of fuel. On cylinders 4, 5, 6 there is only a dribble of fuel. Does anyone have any ideas on what the problem could be.
Re: 230sl fuel problems
« Reply #1 on: December 05, 2014, 19:41:04 »
Check to see if the rack of the injection pump is stuck.
perry113
  • USA, NY, Rensselaer
« Reply #2 on: December 17, 2014, 02:38:20 »
When I first got my 230SL I had a similar issue. I pulled the injection pump out along with the injectors and had it rebuild. Best thing I ever could have done.
Peter Perry
1970 911T Bahia Red
1972 911T Albert Blau
1963 220seb coupe barn
