Author Topic: John Hassle's XR 700 write up  (Read 3557 times)
« on: September 07, 2004, 17:56:56 »
Hello, I am new to the site. I am having trouble installing my XR700. Can you tell me where to get John Hassle's write up.
Lew
1971 280sl
Re: John Hassle's XR 700 write up
« Reply #1 on: September 07, 2004, 18:13:17 »
Welcome to the group Lew.  Send me an email address and I'll mail you the write up.  I installed the Crane system last year in my 1970 280SL.  What's the problem?  Maybe I can help.
« Reply #2 on: September 07, 2004, 18:33:00 »
Thanks for the fast response.
After install I have no spark. The only thing I did to the system is disconnected the ignition box under the battery like the instructions stated. Doing this there is no power to #15 at the coil. Tried a jumper at the harness and still no luck.
Lew
1971 280sl
« Reply #3 on: September 08, 2004, 12:34:06 »
Hi Lew,
Do you have +12 V from the ignition switch connected to the .6 ohm balast resistor? Do you have a connection from #15 coil terminal to the other side of this ballast resistor?
Give me your email address and I'll send the write up.
« Reply #4 on: September 08, 2004, 17:48:41 »
Yes on the first question. #15 goes to the terminal block. I sent you the address.. let me know if you did not get it. :)
Lew
1971 280sl auto
« Reply #5 on: September 08, 2004, 18:49:08 »
Lew, Did not receive email info.  Send again to lax882@aol.com
