Author Topic: Secret switch  (Read 4798 times)
batman
Secret switch
« on: December 14, 2014, 09:17:54 »
I have a small white button (on a sliver plate) attached underneath dashboard (drivers side). My car is RHD. Clearly the switch is not factory standard and has been added but I have no idea what it does. I have pressed it with the car off, with ignition on and with the engine running and but nothing seems to happen.
Has anyone seen something similar - thought I would ask before I traced the electrical cable?
cheers
enochbell
Re: Secret switch
« Reply #1 on: December 14, 2014, 12:08:49 »
I have a similar switch on my 230sl under the dash on the left hand side of the LHD steering wheel.  It is a momentary switch that activates the CSV for easier hot starts.  Check to see if you have an extra wire going to and from the solenoid on the CSV.
g
pj
  • Canada, ON, London, Ontario
  • 1965 230SL
    • my home page
Re: Secret switch
« Reply #2 on: December 15, 2014, 02:50:24 »
I have a mysterious red toggle switch under my dash. Could be the same? Is the CSV-warmer switch shown on the canonical wiring diagram?
Peter J
1965 230SL #09474 named Dagny
2025 GLC300 coupe named Rigel
batman
Re: Secret switch
« Reply #3 on: December 15, 2014, 11:12:25 »
Thanks for the feedback.
There does not seem to be an extra wire to/from the solenoid - will examine under dash further tomorrow.
