When I decided to get a Pagoda, I insisted it be a stick.
I remembered my mother's 71 (bought in '72) with automatic and said no way. Set up to start acceleration in 2nd gear bothered me, and the shift to 3rd was a jerk. 1st gear was for pulling stumps and if you didn't use the gearshift lever to select 1st, you had to hit the kickdown switch by flooring the car. Downshifts by pressing on the gas without the gearshift as I recall were reluctant and required hitting the kickdown switch.
I do understand today that good Pagoda transmission guys can make adjustments to smooth out shifts. Also, using the gearshift and modulating the accelerator pedal to coordinate shifts can be fun. But, all on its own, the automatic transmission left me wanting.
