Author Topic: Clutch reservoir  (Read 3389 times)
awolff280sl
  • USA, FL, Sarasota
Clutch reservoir
« on: December 23, 2014, 12:17:03 »
This is advertised as "CLUTCH RESERVOIR 190sl ponton" :
http://www.vintageeuroparts.com/100029.html
will it work in a W113? (A111290021526)
it looks similar
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
Re: Clutch reservoir
« Reply #1 on: December 23, 2014, 14:00:43 »
Hello Andy,
The 190SL ponton, has no clutch reservoir. It is an all mechanical clutch, using linkages and no hydraulics. It does look like a 190SL ponton "brake reservoir" which is larger than a W113 clutch reservoir.
« Reply #2 on: December 23, 2014, 14:49:13 »
The Clutch reservoir is 'waisted' where it is clamped
Naj
Jkalplus1
« Reply #3 on: December 23, 2014, 15:26:48 »
I bought this part. Looks the same but larger diameter, and has a yellow dot cap instead of blue dot or all black. Smooth textured cap instead of fine grain. It comes with a silver colored mounting bracket, not cadmium or zinc.
I will not be using mine for that reason, I will sell it when I get around to it.
But! It will work, no doubt about it.
J
