Author Topic: front sway bar, symetrical?  (Read 2033 times)
gorgoo
  • France, Île-de-France, Epinay sur Orge
« on: December 28, 2014, 11:08:32 »
While restoring my front axle, I noticed the sway bar wasn't "flat".
That is if I put the chassis mounts flat on the ground ,and right A-arm mount on the ground, then the left one is 20mm above ground.  (see pics)
Is is normal, to compensate for battery's weight for example, or is it an anomaly? How are yours?
Didier.
