Author Topic: Speedometer glass is discolored..... good vendor to send it too?  (Read 3201 times)
ncsurfer
  • USA, NC, Raleigh
  • In good company!
    • Sandhills Motoring Festival, Pinehurst, NC
Hi Guys, The glass on the speedometer appears to be discolored from the lubricant drying out and the speedometer getting hot and making a noise in the head at 45mph and up. I took the rubber cap off of the back of the speedometer to get a better look at the way it is put together, thinking that I might be able to take the glass out to clean it. To me, it looks like a job for a professional. Does anyone have a suggestion on how to do it or where I should send it?
I was just going to re-lube the head and put it back in, but I really don't want to have to go into it again after getting everything back in the dash.
Thanks.......
1970 280sl Horizon blue/navy, automatic
1973 450sl Silver/red, automatic
1985 280sl red/beige, 5 speed
1995 E320 Cab. Black/Cream, Auto
2016 Porsche Boxster Spyder
2008 Porsche Boxster RS 60 Spyder
1964 MB L1113 Firetruck
Re: Speedometer glass is discolored..... good vendor to send it too?
« Reply #1 on: December 29, 2014, 06:50:00 »
There's other posts on this topic, but essesntially you can pry off the chrome bezel yourself, clean the glass, and put it all back together without it being visible that it wasn't done professionally. Of course best to have it done profesionally and the vendor section of the website will have specialized vendors such as Palo Alto Speedometer. Good luck with the repair.
Mike K
    • Mike Kirkinis
« Reply #2 on: December 29, 2014, 08:22:00 »
I had a similar issue, mine was discoloured and I couldn't get it cleaned.
Replacement glass is available: http://www.authenticclassics.com/New-Glass-Mercedes-speedometer-115mm-od-190SL-p/auth-005440.htm
Mike
http://michali.zenfolio.com
