Author Topic: Mechanic recommendation Westchester /NY  (Read 3243 times)
k
« on: September 11, 2004, 09:24:48 »
Dear All,
I have found a truly gifted 113 Mechanic, in westchester,NY/Mount Vernon.
He finally starightened out all issues on my car that had stumped no less that 4 other 113 specialists.
He installed a rebuiltBosch pump, set linkages to factory specs, changed timing chain, adjusted valves, fixed tranmisison speed solenoid,  set timing/ignition perfectly.
My car is  runing the best in 15 yrs; stunning, smooth acceleration with no hesitation, backfiring, lunging, rough idle, etc.
He is the Tech Advsior to the BMWCCA; and has a specialty shop that works on jags, ferrari, maserati, bmw, alfa, rolls etc.
He did a complex repair (ac, catlytic, flex clutch etc) on my bmw 635 csi too!
his name/info:
Mike Shiffer
Euromeccanica
914-668-1300
114 pearl st, mt vernon ny
Kayvan
ps, its two blocks from the Metro North station (15 minutes from grand central); so you can drop off car & commute to city or elsewhere
Re: Mechanic recommendation Westchester /NY
« Reply #1 on: September 15, 2004, 16:10:36 »
Kayvan,
Hi.  Can you please put this contact information into our database of parts/service suppliers?
