Even with the occasional glitces with the stainless systems, I think they are a good choice. I always had good experience working with Mike at Time Valve also. He is quick to take care of any issues and is easy to deal with. I just want everyone to be aware of what to look for. It is a lot more work to go back and fix a problem after the installation is complete. The Time Valve system is very well made. I have been installing them for over thirty years. They are designed to be a clamp-up installation, but I always weld them up, as original. Installation is critical. Its a lot of work, but with a stainless, you only have to do it once in the cars life. A poorly installed exhaust will ruin the feel and drivability of a good car. Common exhaust problems are: leaky connections at the front pipes and manifold, front pipe too close to front right frame member in the engine compartment, improperly positioned or formed pipes, causing vibrations or rattling, sagging or leaking clamp connections, poorly positioned mufflers and resonators, causing noises, and vibrations. Often you will find that a notch is worn completely through the sheet metal of the right rear, lower quarter panel of a pagodabody, from an improperly installed rear muffler. Good clearance around the heat shields is required or you will get vibration noises. Pay attention that you have all the bits and pieces for the exhaust hangers. Here is not a good place to save money. Those expensive flat grey heat deflectors at the hangers really do help the rubber hanger rings last longer. The rear muffler tail pipe ends should mount-up nicely horizontal to, and even with the bumper end. Make sure the rubber bumper is installed in the frame above the rear muffler at the rear, so you do not get a bump noise when you drive over a bump in the road.
