Author Topic: Electric fuel pump questions. 1966 230.  (Read 6709 times)
Paul99
  • United Kingdom, England, Hampshire UK
  • 230 SL White. 1966.
« on: January 24, 2015, 16:36:21 »
my 66 230 did a strange thing today.  Driving with the top down in the sunshine, (car hadn't been used for weeks so thought I would give it a quick drive.)  Started perfectly, drove for a few miles, just thinking everything was going really well... then it just died.  - slight splutter then engine just stopped.
I fiddled around about and got it going again.  Not sure if it was the distributer wires (which were a bit loose ) or thinking it could be the electric fuel pump. I don't believe it has ever been replaced. Cant find anything in the cars history about the pump.
Anyone had experience of a faulty pump - IE: do they tend to go or stop, but not intermittent (assuming the wiring is good)
Is a rebuild easy? or would you suggest a total replacement/exchange?  Don't mind having a go at the rebuild but sometimes it isn't worth trying because of rebuild could be too fiddly. I believe its a short pump kit I would need.
Suggestions please.
Rodolfo
Re: Electric fuel pump questions. 1966 230.
« Reply #1 on: January 24, 2015, 18:44:03 »
Could be the coil as well. When it heats up (by temperature) the old internal insulation doesn't work anymore. You let it cool off: everything back to normal, until 20miles further. And so on.
ctaylor738
  • USA, VA, Falls Church
« Reply #2 on: January 25, 2015, 00:38:57 »
Usually the pumps don't die in mid-air.  Suggest check the battery and ignition system terminals for tightness or corrosion along with Fuse 4.
Cheers,
CT
« Last Edit: January 25, 2015, 01:48:15 by ctaylor738 »
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
RonB
« Reply #3 on: January 25, 2015, 22:28:28 »
One does not forget the possible of intermittent fuel pump relay. Act's just like a bad fuel pump.
Paul99
« Reply #4 on: January 26, 2015, 11:37:03 »
OK thanks.  Which/where is the fuel pump relay please?  I will check it out.
ctaylor738
« Reply #5 on: January 26, 2015, 13:48:01 »
No relay, pump comes on with ignition via Fuse 4.
Chuck Taylor
1963 230SL #00133
Falls Church VA
glenn
« Reply #6 on: January 26, 2015, 23:54:17 »
The 'Tower of Fuelin'/aka Flower Pot in the gas tank maybe starved.  It holds about a quart of fuel.  It is supplied by gas entering the 11 mm(?)square annulus around the 10mm(?) gas return line into the Tower pot.  If these 4 little, almost triangles get blocked with 'crud', the quart of fuel will be gone in 4 or 5 miles(if the tank level is below the top of the pot).   The engine dies and then gas will start slowly seeping into the pot.  Takes hours depending on the resistance of the crud.
Next time it dies, have someone squirt gas(or Starting Fluid carefully) into the intake manifold.   Turn ignition s/w to Start.  If it doesn't run, look elsewhere.
Good luck.....
glenn
« Reply #7 on: January 26, 2015, 23:57:13 »
Also, Hampshire is a 'loverlie'(My Fair Lady) place for a Pagoda....
Paul99
« Reply #8 on: February 04, 2015, 15:45:11 »
Many thanks.  Will check it out.
~Yep Hampshire (old hampshire) is a nice place to be, but a bit too cold at the moment !
