"I found an 8/2014 receipt for replacing the three fuel lines near the fuel pump near the fuel tank to fix a reported fuel leak.
When I put the car on the lift I discovered that the bottom of the fuel pump cover is damp but not dripping."
I have read about expensive fuel pump leaks and this has me concerned.
Might it be normal for the fuel pump to leak a little at first if the car has been sitting for a long time??"
Find out where the leak is coming from first. "Final muffler looks to be at the end of its life since it looks to be corroding through on the bottom."
New original exhaust systems are still available or you can get a stainless steel system for about the same price"The trim around two of the side markers is coming loose and look to have broken tabs.
Where can I buy new ones?"
The side marker lights are available also. In addition, they were used on many sedan models of the era, so good used examples turn up on ebay or your local scrap yard from time to time. There are some minor differences (some with screw some without), slight difference in reflector etc. The lenses are the same on both sides but the bulb assemblies and rubber gasket is oriented to one sid or the other. Be careful not to get the earliest versions which were reflectors only (no lights or bulb assembly)"An earlier reply mentioned the incorrect engine hoses and clamps".
Spend some time and search the subject or look in the Tech Manual, lots of information on this subject is already posted."What is correct and where can I get them?"
Many of the Vendors on this forum sell clamp kits or singles "The turn sign lever does not want to hold in the turn position every time.
I read about filing on the mechanism to correct this.
Any comments on this?"
Fix can be complex, search it and read up to see if want to attempt it."There is a pipe along the rear of the back inside of the trunk that I have read is a "long handled ratchet tool".
Can someone describe it so I know if this is it or not?
It just looks like a piece of pipe to me."
Probably just a pipe. The two piece jack is used in some pagodas. the ratcheting style handle is stored in the end of the jack"The soft top is in fair condition and would work in a rain storm but it looks like the original and has a few wear holes on two corners from being folded up for so many years."
New original material tops are available, check the vendor list"The four speed shift lever is floppy and I need to replace some bushings as I have read."
Also, check the vendor list, I suggest buying a kit with all the plastic bushings."There is a piece of shag carpet over the trunk mat that was placed there the day the car was delivered.
It looks tacky but I like it and will keep it there as a reminder of the original owners attention to caring for the car."
I suppose there is a mirrored disco ball hanging from the deck lid also "The hood strap has a 180 degree twist in it."
Should it have this or was it re-installed incorrectly after the respray?
When I accelerate at full throttle it starts to puke and miss about half way through the rev.
The gas is very very old so I hope this is the problem.
I plan on draining it out today and putting in fresh gas and some Sea Foam.
Two outer rectangular rubber clips on the ridge at the back of the engine bay are missing.
Where can I get these?
What is the radiator expansion tank overflow hose supposed to look like?
Mine is clear hose that is incorrect.
Bottom of engine and transmission is damp but that doesn't surprise me since the car has been sitting for a long time.
Hopefully that goes away but I am probably wishing too much.
As I mentioned before the engine overheated and was replaced at 67k
The head was noted on the receipt as new and has 280 SE A cast on it.
Was this correct or should they have put a head with 280SL cast on it?
The replacement short block is stamped 130.983 whiich means it was a 280SL block but has a serial number 002617 preceding the body VIN by 3,908.
Since the block has a serial number I understand this means it was a used short block out of a previously built car.
If it were to be a factory new block it would not have had a serial number....correct??
All the lights, radio Becker Europia and controls work perfectly
Suspension, brakes, steering all in good order
When I do a in internet search for parts suppliers I am surprised by how few I am finding that carry a lot of stuff.
How about some suggestions?
Thanks again for your comments.
You haven't heard the last from me!!
