Author Topic: Soft Top rubber wedge strips  (Read 4093 times)
jf308
« on: February 24, 2015, 02:49:34 »
I have read the old posts, and the instructions in the Technical Manual.... Sorry, still not clear as to where these two grey rubber wedges/strips glue to the convertible top.  Can anyone help with a photo??
It says they glue to the underside of the top where the frame meets the body in a couple of posts.  Still not clear.  Pls help, otherwise they will go in the parts bin.  :-)
Thanks. John
Re: Soft Top rubber wedge strips
« Reply #1 on: February 24, 2015, 05:21:57 »
John,
here are some pix that JamesHoward (I believe) posted here some time ago. Hope this helps.
mbzse
« Reply #2 on: February 24, 2015, 08:18:17 »
Quote from: jf308
.../...grey rubber wedges/strips glue to the convertible top../...  they will go in the parts bin
I'm afraid that will leave you with a "windy" experience when you drive with the soft top up - similar to not having taut tensioning wires there over the side windows ;)
/Hans in Sweden
« Last Edit: February 24, 2015, 19:46:39 by mbzse »
/Hans S
Paul & Dolly
  • i Car
« Reply #3 on: February 24, 2015, 09:56:29 »
Hi John
They go inside the soft top, above the folding metal frame, above the door windows.
Make sure you clean off any glue/rubber residue from the old soft top, unless you have a new top,
and use a suitable glue, as they tend to unstick when the top is folded for storage.
Good luck
Paul
Mitsubishi i Car
Toyota RAV 4  Hybrid AWD
jf308
« Reply #4 on: February 25, 2015, 15:47:34 »
Thanks ALL....
I was looking in the totally wrong area (along the sides at the rear where the top meets the body) and couldn't figure it out.
Regards, John
