Author Topic: Replacing lights in the instrument cluster  (Read 4509 times)
ncsurfer
  • USA, NC, Raleigh
  • In good company!
    • Sandhills Motoring Festival, Pinehurst, NC
« on: February 27, 2015, 15:24:07 »
I am restoring my interior on my 280sl and in the process, I have sent my speedo and tach out for a rebuild including new lights. While I have the dash apart,  am trying to replace all of the dash lights, including the instrument cluster lights. I did a search on the Technical Manual to see how to replace the instrument cluster lights but didn't find anything. All of the lights are working now, but if it is a real problem to change these lights, I may just pass on it. Any suggestions? Thanks.....
1970 280sl Horizon blue/navy, automatic
1973 450sl Silver/red, automatic
1985 280sl red/beige, 5 speed
1995 E320 Cab. Black/Cream, Auto
2016 Porsche Boxster Spyder
2008 Porsche Boxster RS 60 Spyder
1964 MB L1113 Firetruck
awolff280sl
  • USA, FL, Sarasota
Re: Replacing lights in the instrument cluster
« Reply #1 on: February 27, 2015, 16:28:09 »
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
ncsurfer
  • USA, NC, Raleigh
  • In good company!
« Reply #2 on: February 28, 2015, 02:03:06 »
Thanks, Andy, that was very helpful...
« Reply #3 on: February 28, 2015, 03:43:27 »
I will second that.  After driving late at night last weekend and hardly being able to see the instruments, this post has been very timely and I have ordered some of the lights linked to Alfreds post and will pull down the dash and fit them when they arrive.
« Last Edit: February 28, 2015, 06:44:34 by Garry »
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
ncsurfer
  • USA, NC, Raleigh
  • In good company!
« Reply #4 on: February 28, 2015, 05:16:10 »
I am having trouble getting nut loose on the oil pressure line. I sprayed some BP Blaster on it and will try again tomorrow. Don't want to strip the nut. any suggestions?
« Reply #5 on: February 28, 2015, 06:19:44 »
Steve, in response to your PM,
this connection should be quite tight because you don't want oil leaking down your dash!
I found it best to use two wrenches - a 9mm and a 10 mm - the first to prevent the coupling nut on the gauge to turn and the other to unscrew the line.
Set the 10mm wrench below the 9mm wrench and then squeeze it towards the 9mm, kind of like a scissor closing, but try to keep the 9mm wrench stationary. It will take quite a bit of force but should work.
Good luck!
ncsurfer
  • USA, NC, Raleigh
  • In good company!
« Reply #6 on: February 28, 2015, 13:35:37 »
Will do, thanks Alfred....
ncsurfer
  • USA, NC, Raleigh
  • In good company!
« Reply #7 on: March 01, 2015, 01:40:02 »
Thanks Alfred. I did as you said and got the oil line out, plus I replaced the lights. Is there a list or schematic of all the dash and instrument lights? I had ordered a set of dash lights from Buds Benz and used 7 of the set for this instrument cluster.  Also, I noticed that all of the screws on the back were missing. Any idea about the size of the screws? ONE OTHER QUICK QUESTION: Is there a washer on the threaded end of the oil line? I didn't notice as I took it out and pulled it through the firewall. I don't think there is one but wanted to ask now before I put it back in next week. (I am restoring the firewall and putting on a new pad.) Here are some pics I wanted to share....... Thank you so much. Steve
« Last Edit: March 01, 2015, 15:09:31 by ncsurfer »
