Author Topic: M 130 head help  (Read 2868 times)
rockingchairmotors
M 130 head help
« on: March 04, 2015, 01:10:00 »
I need some help with a head for a M130 engine.  Head that came off the car is a 130 016 32 01 and is the cleaned one pictured.
I want to confirm that I can use this second head.  # is 130 016 08 01.  The dirty (black) picture.  The chart posted in the tech info says it will work but once I took it off it looks totally different.
Will the second head work?  Machine shop says it might be a different compression?  Or a Euro vs. U.S. Head?
Before I spend the $$ at the machine shop I want to make sure it will work.
Thanks for the help
Re: M 130 head help
« Reply #1 on: March 04, 2015, 04:48:12 »
Those two heads are interchangeable.  Also, they both have 9.5 to 1.0 compression.
