Author Topic: Cold Start valve electrical feed on 1969 280SL  (Read 2862 times)
rutger kohler
« on: March 04, 2015, 06:30:32 »
Hi, The solenoid valve I am referring to is the the one mounted on the inlet manifold that squirts the initial petrol/gas into the manifold.  In the wiring diagram in the technical manual, and other literature it is suggested this has a relay. If so where is this located please, or the the electrical feed direct from terminal 50 on the ignition switch?
« Last Edit: March 04, 2015, 06:40:59 by rutger kohler »
1969 280 SL Manual gear shift
1972 280SE 3.5 auto
rutger kohler
Re: Cold Start valve electrical feed on 1969 280SL
« Reply #1 on: March 04, 2015, 07:46:57 »
Think this has been answered by Peter Van Es in the post before this thanks.
1972 280SE 3.5 auto
