Author Topic: Glove Box Rosette Installation  (Read 12736 times)
ctaylor738
  • USA, VA, Falls Church
« on: March 06, 2015, 12:28:40 »
The Mid-Atlantic Pagoda Group recently organized a group purchase of the (reproduction) rosette that surrounds the arm of the glove box door.  The vendor, pagode-markt.de, offered a decent discount and combined shipping for twenty units.  This is a piece that is missing from a lot of cars, including mine.
Here are my notes on installation.
Disconnect the battery ground.
Disconnect the glove box lamp wires from the connection on the side of the heater box under the dash.
Remove the six screws holding the glove box to the dash (two on top, four on the bottom)
Remove the glove box.  This requires a sort of twisting motion to get the spring and arm to clear the left side of the dash.
On a work surface, separate the door from the glove box body by unfastening the spring assembly and removing the four screws.
Prepare the opening on the left side of the glove box for the rosette.  The rosette fits very snugly into the opening in the metal frame of the box.  If there is any lining folded over the opening (common), this will need to be cut out with a razor or an Xacto knife.  Also, there should not be any material or adhesive where the tabs of the rosette will be bent.  Do a trial fit of the rosette as needed.
Put the rosette on the arm and re-attach the door to the glove box with the screws.  Put the rosette in place, but don’t fasten the tabs.  While there is an adjustment, you may have to do some un-gentle bending of the arm to get it to not scrape the rosette.
Put the rosette in place, making sure that it is flush with the covering and correctly aligned, and firmly bend the tabs to secure it.
Install the spring between the arm and box.
Attach the door to the box but leave the screws loose enough that you can adjust the door’s alignment once installed.
Re-assemble, following the reverse of the first four steps.
Adjust the alignment as needed, tighten the screws that hold the door to the box.
This is a good opportunity to replace incorrect hardware and assembly, and to adjust the alignment of the door, fix a non-working light, etc.  Some suggestions based on what I have seen:
Re-glue the glove box liner (or replace it) as needed.
Get the correct hardware for the spring assembly.
Replace the burned out light bulb.
Replace missing speed nuts that secure the sheet metal screws.
All of the six sheet metal screws that secure the glove box to the dash are chrome and all have cup washers.  The two screws on the top are flat-headed, the four on the bottom are oval-headed.
The hinge goes inside the door, not on top of it.  The sheet metal screws that secure it should be matching pan-head, shiny metal (chrome if possible).  The MB replacements are black.
The rubber bumpers at the top should be replaced if they are missing.  If the MB replacements make the door stick out, you can cut them with a razor blade and glue them on.
A rewarding winter project!
Cheers,
CT
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
bogeyman
  • USA, NE, Omaha
Re: Glove Box Rosette Installation
« Reply #1 on: March 06, 2015, 18:37:30 »
Any leftovers you might sell???
Rick Bogart
1969 280SL Silver(180)/Green
1993 500E
1972 350SL
1995 E320 Cabrio
Montreal V8
« Reply #2 on: March 06, 2015, 20:05:52 »
What Bogeyman asked  -----   Thanks, Dale.
Jack Jones
  • Canada, ON, Milton
Jack Jones
1970 280SL 4 Speed
1984 280SL 5 Speed
« Reply #4 on: March 06, 2015, 21:54:32 »
I remember buying one a few years ago for $7  now they are $38. In anyone's language that is called price gouging
RobSirg
« Reply #5 on: March 09, 2015, 09:19:01 »
Guys, was this only on 230SL's or all 113's?
The Authentic Classics ad suggests it was only on 230's :
This Decorative Aluminum bezel was used
on early 230SL's Glove Boxes but fits all 113 Chassis Models.
If only on 230's, what did the other models have? Mine simply has a hole through the leather.
Rob
1962 E Type Jag BRG with Tan
1974 White Alfa Spider 2000
2023 Range Rover
1982 280TE (my daily)
1977 Yellow 911 Targa
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
batman
« Reply #6 on: March 09, 2015, 10:37:41 »
Hi Rob,
I have one on my 280
Jack Jones
« Reply #7 on: March 09, 2015, 13:05:58 »
I also have one on my 280SL.
Jack Jones
1970 280SL 4 Speed
1984 280SL 5 Speed
« Reply #8 on: March 09, 2015, 15:35:38 »
Ditto on my 280 SL (12730). These were on all 113 cars
RobSirg
« Reply #9 on: March 09, 2015, 22:35:44 »
Thanks Guys - good to know,
I look forward to crossing it off the list - it certainly looks better finished with it installed.
It still begs the question why Authentic Classics didn't simply say "for all 113's" as opposed to :
"This Decorative Aluminum bezel was used
on early 230SL's Glove Boxes but fits all 113 Chassis Models."
Rob
2023 Range Rover
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
michaelgread
« Reply #10 on: March 11, 2015, 12:09:00 »
I had an idea that the later cars had a plastic rosette, which always got brittle and broke away.
Flyair
« Reply #11 on: March 11, 2015, 16:24:12 »
Chuck,
your post just reminded me that my Pagoda also lack this part. Now with such detailed guidelines there is no more excuse not to install it.
Stan
2011 SL550 AMG
2011 GL
2015 GLA
Mike K
« Reply #12 on: April 15, 2015, 07:02:21 »
I've just repaired my glovebox, the door kept dropping open. Works like it should now, fitted the rosette which was missing, new spring and rubbers,
all purchased from Authentic Classics.
FWIW I had to use the old forks with the new spring.  The new forks which arrived with new spring wouldn't fit into the spring....
tel76
« Reply #13 on: April 16, 2015, 10:33:41 »
I did report this several months ago, only to be told by one of our members that It was not possible and i was wrong (the parts I obtained were from MB), I fitted a modified oil pressure relief spring, please do not tell the authentic brigade.
Eric
