Author Topic: Clutch fluid  (Read 2962 times)
michael113
Clutch fluid
« on: March 10, 2015, 10:34:47 »
What clutch fluid do I put in a 1964 230 SL manual transmission
UJJ
  • USA, CA, Grass Valley
Re: Clutch fluid
« Reply #1 on: March 10, 2015, 11:43:29 »
I replaced both master and slave cylinder and the hose last year and I used synthetic brake fluid.
However, if you just want to top it off you should use the same fluid which is in there.
If you flush it completely I recommend the synthetic fluid, since it does not pick up moisture.
Urban
Urban Janssen
Grass Valley, CA
1968 280 SL - 4speed manual
173 anthracite grey
