Author Topic: Colors of interior lights for heater levers  (Read 5903 times)
« on: September 17, 2004, 22:51:24 »
I just had the horror of having my heater levers replaced.....yes I started to do the job myself by must admit I did not have the patience for it.....anyway...after paying more than I wanted to I noticed that when I turned the headlights on at night and the dashboard lights up that I have one blue light on the upper left lever and the rest of them have a red backlight....is this correct??  I think I had one blue one white and 2 red backlights before....
Dan
Re: Colors of interior lights for heater levers
« Reply #1 on: September 17, 2004, 23:21:57 »
I always thought it was the color of the plastic of the levers that gives the lights its color?
« Reply #2 on: September 18, 2004, 03:45:12 »
I just supplied a friend with these levers - 2 red, one blue, one clear.
Yes, the upper right lever (for air direction up/down) should be clear or smoke gray
« Reply #3 on: September 18, 2004, 22:02:01 »
My '69 has the black levers but I have the two red one blue and one clear.  I must admit that the early levers were so much nicer looking. :D
gwuisman
  • Keep it simpel
« Reply #4 on: September 19, 2004, 01:03:12 »
The collor sceme is simpel. There are the two lower levers which relate to the hot air of the heating. They have red plastic caps. The upper left conducts the cold air inlet in front of the windshield. It has a blue cap. The upper right lever makes the cold and hot air flow up or down. Its cap is white. All levers are enlighted by white bulbs. Perhaps you can ask your mechanic to replace the upper right lever by the right one. He made the mistake and should correct it. In our country this would be question of guaranty.
Gerard Wuisman
1970 280sl
« Last Edit: September 19, 2004, 01:04:17 by gwuisman »
« Reply #5 on: September 19, 2004, 07:32:59 »
Dan,
What kind of car do you have??  In my 230SL, there are only TWO blubs.  One clear blub in a clear plastic cylinder around which the TWO left levers are attached.  Another for the two right levers.  The transparent (translucent?) plastic in the colored plastic levers produces the color.
Do 280SL's use 4 bulbs because the levers are not transparent/translucent?
« Reply #6 on: September 19, 2004, 09:47:48 »
Rodd,
280s have the same arrangement as the 230s with a bulb each in the two clear plastic barrels. The difference is the later levers which have the rubber knobs. Also, the bulb holders are somewhat more modern??
« Last Edit: September 19, 2004, 09:48:58 by naj »
« Reply #7 on: September 21, 2004, 19:23:14 »
I found out that the heater levers were installed correctly, 2 red on the bottom, one blue in the upper left and one smoke grey in the upper right however the smoke grey lever appears to be backlit in red when the dash lights are one.....the mechanic who installed them cannot figure out why....any advice from the pros??? I thought it might be the placement of the lightbulb in the clear plastic cylinder but he ruled that out.....any advice would be greatly appreciated
Dan
Chad
« Reply #8 on: September 08, 2005, 21:32:26 »
My 230 SL has the early levers.  At night NONE of them light up. I assume that either both bulbs are toasted and need replaced, or, that there is a fuse out that resulted in no juice to the bulbs.
My question:  Which fuse, on 230 SL, would be the one?  Or, is there a simple way of replacing the bulbs WITHOUT removing the levers and doing the half-day full-day job outlined in the Pagoda World winter article?  The levers work fine otherwise, they just do not light up.
-CD-
1967 230SL, 113.042 10
1983 300TDT, 123.193
TA250SL
« Reply #9 on: September 08, 2005, 21:42:57 »
I remember accessing the bulbs from the speaker opening.  Remove the grill and speaker, then you will find two black plastic caps that cover the bulbs in the center of the levers.  Easily removed and replaced.  Good luck.
Los Angeles
Chad
« Reply #10 on: September 08, 2005, 21:46:49 »
Fantastic!!!!
Thanks Tom.
--Chad
-CD-
Chad
« Reply #11 on: September 08, 2005, 21:48:24 »
Does everyone use 2W bulbs? Has anyone uprated to 4W?
I can't wait to see the glow through the levers; hope I don't snap them somehow!
-CD-
« Reply #12 on: September 09, 2005, 16:33:23 »
Hello Chad,
Not sure whether the 4W bulbs will eventually burn the light domes within the heater levers, but the illumination might appear just too bright.
I know, these old-fashioned bulbs are not easily available everywhere; nevertheless, I recommend getting them from Mercedes-Benz. They're cheap.
Make sure to clean up (towels, Q-tips) as much of the "colored" plastic as possible, the better will the illumination of your heater levers be. It just looks fantastic. Put also a little drop of oil on to the ends of the wires attached to the levers. Makes using them easier.
Good luck!
(Magdeburg, Germany)
