Author Topic: FIP "Overflow" (Bypass) Valve - where is it?  (Read 2640 times)
awolff280sl
  • USA, FL, Sarasota
« on: March 15, 2015, 18:19:50 »
My '69 280SL has a R20Y FIP using the short fuel pump.
I want to check to see if the overflow (bypass) valve in the FIP has a "vapor" hole in it or not, in order to determine whether or not to hook up a bypass line.
Where is that valve? Is it where the hose from the damper connects to the FIP outlet?
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
awolff280sl
  • USA, FL, Sarasota
Re: FIP "Overflow" (Bypass) Valve - where is it?
« Reply #1 on: March 18, 2015, 12:53:26 »
FYI, I spoke with Hans at H&R Fuel Injection. He has a great deal of experience working on our FIPs.
The overflow/bypass valve is fitted between the outflow port of the FIP and the hose to the damper. The bypass valve on my R20Y pump does have a vapor orifice.
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
