The tech at Bud's says I've got .089 run in/out on the crank but it's still within the .090 tolerance. I've never laid eyes on the (.090) spec in the BBB and I'm not even sure where this tolerance is published.
Ths motor runs strong, uses no oil, and keeps the oil pres gauge pegged at all times-regardless of rpm; I certainly don't want to tear it down. So,,I guess you guys know where I'm going with this..I'd like to be able to drop the lower pan, the bearing cap, and insert a wider thrust bearing. Before I attempt, i'd like to get an idea of how that cap and bearing looks. thanks, charles
