Author Topic: Stickers  (Read 3331 times)
Stickers
« on: April 12, 2015, 11:14:50 »
My car is off on a regularity rally next month
They want to stick vinyl stickers on the door. Is there anything I should be putting on the doors before they stick so that I can get the stickers off afterwards with no risk of damage?
Flyair
Re: Stickers
« Reply #1 on: April 12, 2015, 12:55:24 »
James,
if these are magnetic stickers it won't work. But if this is to be glued it depends very much on the paint quality. I saw my friend's car that had some nasty marks after he removed the stickers after a rallye. It looked like the veneer or clear paint entered into some chemical reaction.
Stan
2011 SL550 AMG
2011 GL
2015 GLA
Re: Stickers
« Reply #2 on: April 12, 2015, 13:31:25 »
Thahks Stan
Very reassuring! ;D
Oh, I don't think it's the sort of serious stuff Peter does...
Re: Stickers
« Reply #3 on: April 12, 2015, 18:19:38 »
Mix a spray bottle with water and one teaspoon of washing up liquid. Apply to door before sticking sticker. Then you can still move it around a little. Remove bubbles with a credit card or similar plastic object at an oblique angle.
To remove... Wet the edges and the heat slightly with a hair dryer.... Carefully. Shouldn't be a problem.
