Author Topic: Motor mount bolts  (Read 3490 times)
jan lauwers
  • Belgium, Antwerpen, Geel
Motor mount bolts
« on: April 13, 2015, 08:58:19 »
Hello Folks,
While my engine is out I am taking the opportunity to replace the parts that are obviously worn out.... so I have bought new motor mounts. The right one was torn apart which is not uncommon from what I read here.
My supplier told me that the bolt that is sitting in the sub frame and going upwards, exists in 2 lengths and that I may have to shorten the ones that he gave me. From what I can tell at first sight, mine look a bit long indeed, I.e. 84mm, the head included. To show you want I am talking about, I add a pic and the drawing... it is the bolt nr 6. I don't want to make a mistake if I am going to shorten them. Does anybody know how long they should be?
Many thanks!!
Jan
Jan Lauwers, Geel, Belgium
White 280 SL 1969
Re: Motor mount bolts
« Reply #1 on: April 13, 2015, 13:09:35 »
Hello Jan,
The bolts you have look incorrect.  Normally the bolts have a long shoulder and a short length of thread. The bolts you have look like the correct bolt for the rear motor mounts used on  the earlier Mercedes "ponton" sedans and the 190SLs.
jan lauwers
« Reply #2 on: April 13, 2015, 13:56:40 »
Thanks Joe... that sounds like shortening them is not going to be right. I ll try to find the correct ones.
Jan
White 280 SL 1969
« Reply #3 on: April 14, 2015, 03:38:10 »
Joe is right about the bolts. That flat washer is probably welded on to the bolt head. If so, it is a rear Ponton mount bolt. I just replaced the ones on my '60 220SE a couple of weeks ago. Those bolts are fully threaded for a reason.
RonB
  • USA, MN, Cottage Grove
« Reply #4 on: April 15, 2015, 03:17:33 »
You might want to check your sub frame mounts. Especially if they are original.
Enjoy when finished.
Previously FULL Member twice with over 500 post
71 280SL - SOLD on BAT
97 E420      SOLD
85 300D      SOLD
85 R107 380SL
07 Volvo S60
