Author Topic: Poor Gas Mileage  (Read 8154 times)
bubbl
Poor Gas Mileage
« on: April 19, 2015, 19:43:57 »
My '69 280 SL, which I have had for about a year, exhibits what I think is poor gas miileage.  I have never gotten more than about 15 mpg, with little difference between city and highway.
A few months ago, I had the engine and injector pump completely overhauled (The car had been in storage for a number of years, and there were corrosion and other serious prolblems  ~$20,000!).
Enigne and car now run very smoothly and quietly, with plenty of pickup, etc.  But the gas mileage has, if anything, become worse.  The injector pump has been carefully checked by someone I believe is a well-experienced mechanic, specializing in old Mercedes.
Is poor gas mileage a basic characteristic of this car?
Charles Ostrofe
ctaylor738
  • USA, VA, Falls Church
Re: Poor Gas Mileage
« Reply #1 on: April 19, 2015, 22:54:49 »
I would say that's about average, or a little better, for mixed driving.
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
RonB
  • USA, MN, Cottage Grove
« Reply #2 on: April 20, 2015, 01:40:07 »
When you did the pump - did you clean the injector lines?
Where the injectors check for spray pattern and volume?
This all make a difference.
Previously FULL Member twice with over 500 post
71 280SL - SOLD on BAT
97 E420      SOLD
85 300D      SOLD
85 R107 380SL
07 Volvo S60
« Reply #3 on: April 20, 2015, 04:30:51 »
My car has always gotten around 18 mpg (US) in mixed driving.
Compare this to around 27 mpg for my 272 hp modern Volvo S80 with its twin turbo straight six and substantially greater weight.
« Reply #4 on: April 20, 2015, 10:12:45 »
I'm getting 16.9 mpg (US) on average for the least three years... (13.9 l / 100 km).
batman
« Reply #5 on: April 20, 2015, 11:40:49 »
The technical data contained in the Mercedes brochures for the 280SL claim a fuel consumption of 25 miles per imperial gallon/20.5 miles per US gallon at a constant speed of 100 KPH/68 MPH on even road.
« Reply #6 on: April 20, 2015, 15:37:12 »
That's possible but I'm thinking those figures are for a new car with everything working in top condition.
49er
  • USA, CA, El Dorado Hills
« Reply #7 on: April 20, 2015, 17:06:01 »
 16mpg average for mine since getting the car back on the road. 99.9% of our driving these days is on 2 lane roads and at a "leisurely" pace. 20mpg+ sounds about right for when the car was new and driven frequently on the freeways. Those were also pre unleaded, pre ethanol days too.
John
1969 280SL 003820
Rodolfo
« Reply #8 on: April 20, 2015, 18:09:56 »
mine does 12l/km. Which would mean 23,5 mpg (imperial) Or 19,6 mpg (US).
On the highway it is even slightly better.
« Last Edit: April 20, 2015, 18:27:23 by Rodolfo »
enochbell
« Reply #9 on: April 20, 2015, 18:32:27 »
At 15 mpg it sounds like you are on the low end.  Overhauled IP and engine may not tell the whole story.  Was the setup and adjustment done by an expert?  The linkage is very sensitive and you may just not be dialed in correctly.
g
« Reply #10 on: April 25, 2015, 12:20:20 »
I get around 10 km per liter or about 27 - 28 miles per imp gallon.
alchemist
  • USA, NY, GRAND ISLAND
« Reply #11 on: April 25, 2015, 15:25:54 »
I get about 16-17 miles/gallon for mixed driving with my 67 230SL that has M130 engine. I have another one with M130 engine, 1972 250C gets about the same.
charlie
« Reply #12 on: April 30, 2015, 04:15:00 »
If you think your fuel mileage Is still to much you can check the cold start valve . It has happened to me that the Cold start  valve has stuck on and then you will Use a lot of fuel.  Cheers Charlie
pdc
  • Belgium, West-Vlaanderen, Koksijde
« Reply #13 on: April 30, 2015, 05:39:09 »
Reading this thread I got curious especially since my injection pump got overhauled and injectors tested so I decided to do find out what my consumption was.
had my red reserve light on for a while and filled it up : 71,18l
Drove 596 km and reserve light was on again when I filled it up again and the nozzle stopped at 67,13 L
Not sure I pushed more in after the nozzle stopped the first time
Not sure what was left in the tank when I refueled second time
Take the average of both refueling = 69,155 l
69,155/5,96 = 11,6l / 100 km
2.905893 gallon/62,1371 m
21,38 Miles / Gallon   ( hope my conversion is done correctly)
took pictures of everything to remember  ;D
about the type of rides I did, mix of highway ( about 220 km at about 100km/h in one track) and several local trips thus with several cold starts.
Take a peek at the price per liter on the pictures..... :o
« Last Edit: April 30, 2015, 05:57:36 by pdc »
late 67  250SL
4 speed manual
Euro version
Pascal
kampala
  • USA, CA, Beach Cities
« Reply #14 on: April 30, 2015, 06:27:21 »
I think your math shows "imperial" Gallons.  In USA Gallons you are getting about 20.27 miles per USA gallon ---  very good mileage.
250sl - later - manual
280sl - 1971 - Auto - LSD
