Become a
Full Member
Emergency Contact List
Oil cooler question
Topic: Oil cooler question (Read 2733 times)
rjfurlan
Oil cooler question
April 26, 2015, 23:46:27 »
I changed the oil in my 1967 250sl for the first time. I was confused about draining the oil cooler. I cracked open the 19mm bolt on the bottom of the oil cooler and coolent came out. I retightened the the bolt and now it is dripping.
1) Is the small brass(?) washer that came with the oil filter kit for that bolt?
2) can you drain the oil out of the oil cooler and if so where is the drain plug?
Rich
Associate Member
Platinum
Canada, ON, Port Lambton
Re: Oil cooler question
April 27, 2015, 04:18:32 »
There is a drain plug on the oil cooler but it's not for oil as you found out. Drain your oil in the normal fashion at the oil pan and use a new O-ring on the filter canister and a new copper seal on the drain plug. You may need to drain your coolant so you can replace the leaking seal on the oil cooler.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
rjfurlan
Reply #2 on:
April 27, 2015, 04:32:54 »
Thanks, so is the seal I need the one that came with the Mahle ox47d filter kit, the small copper looking one?
Oil cooler question
