Author Topic: Spark Plug Gap w Pertronix  (Read 6171 times)
vande17941
  • USA, CA, Irvine
« on: May 05, 2015, 23:13:47 »
hi. Could somebody with experience please tell me a good starting gap for a 7 or 8 Bosch heat range plug after upgrading to the Pertronix electronic ignition with the Pertronix hotter coil In a 230sl.  Thanks
'66 USA (1967 model Year) 230sl, 4-speed Manual, Driven Like a Real Car! Set up with KYB Stiffer Shocks, and Motor Mounts w Urethane Inserts Underneath, 3-point Belts, Headrests Installed 🚗
1986 560sl Cabernet & Palomino (not recommended)
2001 SLK320 Sport AMG Silver & Black
Re: Spark Plug Gap w Pertronix
« Reply #1 on: May 06, 2015, 00:33:57 »
Use NGK  BP5ES instead; gapped to about .035''
vande17941
  • USA, CA, Irvine
« Reply #2 on: May 06, 2015, 18:21:06 »
Will do. That's a bit hotter plug....I drive that Pagoda hard....mountain roads, high speed cruise etc. ...it is not a trailer queen and it is definitely not even close to babied...I'm a past shifter kart racer. ...is that still okay with an NGK "5" plug?
« Reply #3 on: May 06, 2015, 23:51:11 »
I think so. The 5 crosses over to about a 9 in Bosch but they are not making any more non resistor plugs so that's why I changed to NGK. The fuels are different today than 40 years ago and most spark plug reconmendations are out of date. Every book I've ever looked at all called for a 7 in Bosch but they're too cold for almost every application I've worked on.
vande17941
  • USA, CA, Irvine
« Reply #4 on: May 07, 2015, 03:47:53 »
great. Thanks. I'll give it a try and then read the plugs and see how I do.
« Reply #5 on: May 07, 2015, 12:04:50 »
Dan, I've been running NGK BP6ES for a long time. Based upon your note here, and since it's about time to change/look at the plugs anyway, I just ordered a set of BP5ES.
This -5 is a hotter plug than than the -6, yes?
What should I expect if anything, in operating? What should I be looking for to see if this is better, worse or about the same?
I too have a Pertronix...and the -5 is gapped to about .035.
« Reply #6 on: May 07, 2015, 13:14:58 »
5 is a bit hotter than a 6.
 Look for a uniform tan colour on the insulator around the center electrode. The outer shell is often black but that's not a problem. If the insulator remains bone white after a short amount of driving you are actually too lean and it's not a function of having a spark plug that's too hot.
 You should see a nice warm up cycle without any loading up, hesitation, or real changes in the exhaust note. Engine should pull hard warm or cold.
« Reply #7 on: May 07, 2015, 13:40:03 »
We'll give it a go!
vande17941
  • USA, CA, Irvine
« Reply #8 on: May 07, 2015, 15:01:07 »
NGK lists BP5ES under 2 different stock numbers.  I suspect one has a removable terminal end, which is what I need. Anyone know which model we want, 6511 or 7832 with the removable terminal?
« Reply #9 on: May 08, 2015, 03:23:01 »
6511 is the base copper core plug that comes with the 4mm threaded stud without the threaded nut and the 7832 has the threaded stud with the removable nut.  The real difference for you is the 7832 features better plating to help keep it from seizing in the cylinder head.
vande17941
  • USA, CA, Irvine
« Reply #10 on: May 08, 2015, 06:26:52 »
Great info...thanks everyone.
