Recently I'm having trouble starting my car and believe the linkage at the Neutral Safety Switch may need adjustment - assuming that's possible - or, do I need to replace the switch? If it is adjustable, is there a procedure to re-adjust the linkage? Currently, sometimes it won't start in Park position but moving to Neutral works. Or, sometimes, applying pressure to the Trans lever in Park will allow it to start.
