Author Topic: My favorite 280SL tool  (Read 5941 times)
MBdude
« on: May 11, 2015, 14:36:22 »
Here is my favorite tool.
It comes out of the trunk every time I open the hood on my 280SL.
It took about five minutes to make out of a 3" x 2" x 6" piece of foam with a slit in the middle.
Procrastinators remember this post every time you whack your head on that pesky hood latch.
Matt113
Re: My favorite 280SL tool
« Reply #1 on: May 11, 2015, 17:22:57 »
Excellent idea!
kampala
  • USA, CA, Beach Cities
« Reply #2 on: May 11, 2015, 23:24:37 »
What's the part number for that special tool?  Couldn't find it in the BBB or the EPC or at SLS or at Buds, Millers, KKM --- Hey I bet Stan's friend Kristophe makes them.
Here's my pagoda hood/bonnet war-wound selfie --  I hit that latch 18 months ago  -- didn't want stitches, so now I have a scar --- but it's finally tanned to match --- must be the topless driving.
« Last Edit: May 11, 2015, 23:30:21 by kampala »
250sl - later - manual
280sl - 1971 - Auto - LSD
Rolf-Dieter ✝︎
  • Canada, ON, London
« Reply #3 on: May 12, 2015, 01:10:36 »
Great Idea, I have to make one ~s~ then I have to come up with a similar tool for my Dodge Caravan Wheelchair Van, each time I go up the rear ramp I bank my head (well not each time several times anyway and it hurts) :)
Oz, Must have hurd bad for several days :( glad you are okay!
« Reply #4 on: May 12, 2015, 04:10:44 »
That's an odd thing. ??? Maybe it's because I've hit my head a few times on the opened hood of an older sedan so I've becomes used to ducking, or possbily it's because I'm six foot four inches and I have to duck for everything anyway, but I've never been hooked by the hook.  ;D
 Ofcourse, that could change tomorrow........... :(
Flyair
« Reply #5 on: May 12, 2015, 07:31:27 »
Oz,
dont think he makes them, but it wouldn't hurt asking ;)
As for your selfie, one could collie that your addiction to Pagodas marked you for life ;D
Stan
2011 SL550 AMG
2011 GL
2015 GLA
Paul & Dolly
  • i Car
« Reply #6 on: May 12, 2015, 08:20:50 »
Oh !
I have never before recognised this as a problem, (good solution though)
I just hope that this is not now to become one of those instances where we all start to suffer  "Attack by The Hook",  now we have been exposed by MBdude and Kampala
Keeping my head down (hopefully)
Paul
Mitsubishi i Car
Toyota RAV 4  Hybrid AWD
MBdude
« Reply #7 on: May 12, 2015, 14:18:10 »
I'll amend my original post to say that possibly everyone doesn't need one of these.
If you only plan on changing the air filter or topping off your radiator surge tank or maybe polishing your intake manifold then no problem since these require access only on the right side.
Now if you plan on changing the spark plugs, replacing points, checking your brake fluid or fiddling with the fuel injection pump then that is another matter.
Either way, I guarantee you will remember this post when you whack your melon.
Left side mechanics beware!!
« Reply #8 on: May 19, 2015, 22:29:49 »
You can adjust your hood so it will open all the way by moving the resting block for the prop rod as far forward as it will move. I've seen cases where the hood was only opening about half as far as it could go and if that's the case, yes, you will hit your head on the hood latch.
