Author Topic: Unknown Parts  (Read 4322 times)
drawho
Unknown Parts
« on: May 18, 2015, 17:53:00 »
Putting together a 1970 280SL that someone else took apart.
He was taking apart a 280SE at the same time.
Here is a photo of 10 parts.
Can someone or all of you be so kind as to tell me where they go.
Howard
Flim
  • United Kingdom, England, Flimwell, East Sussex
Re: Unknown Parts
« Reply #1 on: May 18, 2015, 19:53:52 »
Number 4 could be the retaining pins for the brake pads (brake caliper)....
The rest looks like shrapnel to me..... Hopefully the experts may have some ideas.
Charles
georgem
Re: Unknown Parts
« Reply #2 on: May 18, 2015, 19:56:33 »
OK, I`ll start with the couple that look familiar:
7 - heater cable from the dash control to the fresh air flap.
8 - heater valve control lever (possibly)
2 - look like brackets to hold the radio in.
3 - could be the regulator off the previous owners b-b-q gas bottle;D
I hope I get at least one correct.
cheers
George McDonald
Brisbane
230 Sl
1973 VW Kombi Single Cab Ute
drawho
Re: Unknown Parts
« Reply #3 on: May 18, 2015, 20:20:08 »
Number 7 is a tube.
Number 3 --I have tow of these I bet they are off welding and cutting torch tanks.
Number 1 (left side is a dashpot damper rather stiff) Do not know where it goes.
I think the smaller pieces are to hard to see.
Let me try a close up
Re: Unknown Parts
« Reply #4 on: May 18, 2015, 20:32:08 »
Dear drawho. I merged your two posts, and deleted the duplicate. Posting the same message in two different sections is called "cross-posting". That's a no-no in forum land.
drawho
Re: Unknown Parts
« Reply #5 on: May 18, 2015, 20:39:50 »
1.) is a very small shock absorber or dashpot
7) is a very small hole with fittings.
5) see close up attached
hkollan
  • Spain, Castilla-La Mancha
Re: Unknown Parts
« Reply #6 on: May 18, 2015, 22:14:09 »
1 is an engine damper found on some w108/w111/"w112 cars, not for your pagoda
7 could be early style oil pressure line?
6 upper brackets for headlight chrome trim on w108/w111/w112 thus not for a pagoda
I believe 2 and 4 have been correctly identified
Hans
Hans K, Cuenca, Spain
drawho
Re: Unknown Parts
« Reply #7 on: May 18, 2015, 23:04:39 »
Thanks everyone,
We have 5,8,9, and 10 left
5) the part sticking out is threaded
9) these look to attach with screw to hold the edge of something.
10) I found 9 of these-- see closeup of 8,9,10
Howard
badali
  • USA, Pa, Butler
  • 1966 230SL
Re: Unknown Parts
« Reply #8 on: May 19, 2015, 16:26:50 »
5 looks like a clip that holds the end of the garnish trim on top of the doors
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
