Author Topic: Caulk Type Sealant  (Read 4127 times)
Jack Jones
  • Canada, ON, Milton
Caulk Type Sealant
« on: May 19, 2015, 02:20:42 »
I am looking for the caulk type sealant used on the windscreen trim and other areas. It looks like a type of butyl tape that does not set up like silicone.
Jack
Jack Jones
1970 280SL 4 Speed
1984 280SL 5 Speed
Re: Caulk Type Sealant
« Reply #1 on: May 24, 2015, 20:15:30 »
Jack Jones
« Reply #2 on: May 25, 2015, 01:19:38 »
Thank-you Shvegel but this product cures and what I am looking for does not. It appears to be a mastic type of material and further investigation has proven to be a butyl product.
Jack Jones
1970 280SL 4 Speed
1984 280SL 5 Speed
hkollan
  • Spain, Castilla-La Mancha
« Reply #3 on: May 25, 2015, 06:29:52 »
This is what I'm using for window sealing. Does not cure and its pretty easy to work with, as you
can use a chunk of the material to dab off excess material.
Info here, I assume its available from Würth in Canada as well.
http://www.wurth.co.uk/technical-chemicals/sealants-and-sealing-materials/bodywork-seals/glass-sealant-dab-off-310ml
Hans
Hans K, Cuenca, Spain
« Reply #4 on: June 01, 2015, 14:28:46 »
Here is another very universal alternative. I am going to use this for the windshield seal and other areas that require a thick, non-hardening, easy to apply caulk ribbon. Also works great for sealing screws that go through the firewall.
http://3mcollision.com/products/sound-deadening/3m-strip-calk-08578-black.html
I have used it for years and works great. Simple, cheap and no shelf life!
