For a 1970 280SL.........
Just about ready to start up the engine after the head was off for some new valve guides, and set of new valve seals.
Since the workshop book we are working from is pretty poor, and our job doesn't exactly follow other Forum Threads,
I would like some confirmation we have the timing correct....
Neither the fuel injection unit nor distributor were removed / disturbed.
The chain was replaced by normal, feed-round method.
With no.1 camshaft lobes pointing up (firing), the camshaft & pillar marks lining up, the crank at TDC and the rotor-arm pointing
at the slot on the edge of the distributor-body......is this correct timing ?
One thing that threw us was the fact the inj.pump pipes are ordered (front of engine to back) no.6 > no.1........
