Author Topic: Pistons  (Read 3846 times)
AndersO
  • Sweden, Skane, Barsebäck
Pistons
« on: May 27, 2015, 11:59:12 »
I am trying to restore a 280SL block ( engine number 130 983 12 - 014205) which supposedly comes from the US. The restoration was started by someone unknown, the bore is now 87.50 mm and good, and I need to find pistons that fit.
Does anyone know if I can use the EU type pistons with a compression height of 48.6 mm and the length of 80.6 mm, instead of what I believe to be the MB specs with compression height 47.9 mm?
Many thanks,
Anders in Sweden
Re: Pistons
« Reply #1 on: May 27, 2015, 14:49:06 »
Doe this help?
AndersO
Re: Pistons
« Reply #2 on: May 27, 2015, 16:25:56 »
Thanks Naj,
These are the pistons I want to buy. The question is if they will work in the US Automatic engine?
Re: Pistons
« Reply #3 on: May 27, 2015, 20:51:13 »
Hi, AndersO,
According to my interpretation of the EPC, Both Euro and  US engines after engine # 12 007230 use the same pistons.
The standard piston part # is 130 030 8917.
I could not find the part #s for the oversize pistons.
Hope this helps
AndersO
Re: Pistons
« Reply #4 on: May 28, 2015, 07:11:46 »
That is reassuring.
I have now ordered and hope for the best.
Many thanks,
Anders
AndersO
Re: Pistons
« Reply #5 on: June 29, 2015, 13:29:54 »
Pistons are now in place, and although the engine is far from complete, they seem to fit very well.
Re: Pistons
« Reply #6 on: June 30, 2015, 01:51:50 »
I've found that over size pistons are a bit shorter so that you can deck the top of the block which is usually needed anyway.
« Last Edit: July 02, 2015, 22:36:22 by Benz Dr. »
