Author Topic: 280SL late head bolts  (Read 5579 times)
« on: May 29, 2015, 16:40:04 »
Does anyone happen to know the PN for the late style head bolts on a 280SL? They measure 115 mm and 145 mm respectively, which is 5 mm longer than the earlier version. I would also be interested in a set if anyone has any spares.
Jack Jones
  • Canada, ON, Milton
Re: 280SL late head bolts
« Reply #1 on: May 29, 2015, 17:59:12 »
Dan,
I have a Aug 1970 280-SL with engine #130983-10-007297 and the head bolts are 140mm (000912-012039) and 105mm (000912-012029). When I look at the EPC it states that these numbers were used until the end of the 113 production.
Jack
Jack Jones
1970 280SL 4 Speed
1984 280SL 5 Speed
« Reply #2 on: May 29, 2015, 19:05:07 »
Dan,
Jack
The BBB states that the head bolts were made longer by 5mm up to 115 and 145mm.  Which one is correct?
« Reply #3 on: May 29, 2015, 19:27:14 »
The late head bolt numbers are:
 000912 - 012040 for the lomg bolts ( 145 mm )
 000912 - 012032 for the short bolts  ( 115 mm )
« Reply #4 on: May 29, 2015, 20:12:54 »
This sls picture explains all:
http://www.sls-hh-shop.de/en/230-280SL-W113/03-Engine-M127-M129-M130/05-a-Zyl-Kopfschrauben-Info/?_artperpage=10&listorderby=oxstock&listorder=desc
Seems like the longer bolts were used on 130.980 engines after 12 069853
« Last Edit: May 29, 2015, 20:27:48 by Naj »
Jack Jones
« Reply #5 on: May 30, 2015, 02:13:46 »
Mine are definitely the shorter bolts as I currently have the engine apart and measured them before my first response.
Jack Jones
1970 280SL 4 Speed
1984 280SL 5 Speed
« Reply #6 on: May 30, 2015, 03:11:53 »
PN 000912 - 012040  has been subbed over to 615-990-03-12 which has a 12 point head probably used on a diesel. It is the right lenght though.
Jack Jones
« Reply #7 on: May 31, 2015, 01:38:54 »
I realize this is probably a silly question but will the block accept the longer head bolts?
Jack Jones
1970 280SL 4 Speed
1984 280SL 5 Speed
