Apologies if this has been covered but I am having an issue with my soft top frame. It's been a constant battle to keep all of the connection points tight but most recently I had one of the flat top bolt/screws pop out of the frame. There are only two flat tops as far as I know and this one is on the driver's side. This is the connection where when the top is up the connection point is hidden behind another, thus the need for the flat top bolt/screw. In trying to reattach I find that the point that the bolt/screw threads into may be stripped as the screw goes in but won't tighten down and just pops out again. I tried just screwing the bolt into the connection point without going through the hinged bar firs just to test it and as I said it just spins and won't bite. I tried another screw to see if that was the problem, but same result. Is there a fix that anyone knows of short of a new soft top frame? Thanks.
