Author Topic: Convertible Top Maintenance  (Read 17561 times)
« on: September 28, 2004, 15:24:12 »
 :?: What maintenance can be done to the frame (with the canvas on) to prevent issues?  Do the joints in the frame need to be lubed?  If so, with what to avoid staining the canvas?
Are there adjustments that can make the top work better?  For example, I have to pull the frame forward and yank it for it to reach and fall into the holes on the windshield frame.
Hints and tips are appreciated!
Thanks!
Memphis, TN.
1997 E320
Re: Convertible Top Maintenance
« Reply #1 on: September 29, 2004, 14:08:48 »
I have only cleaned (with some steel wool) the frame - some tarnish/dirt had formed over the years on the chrome surface. Have not lubed the joints, although this might be a good idea. One thing to make sure of is that all of the bolts are in tight. They sometimes work themselves loose.
As for the fit, I have to do the same as you: after I press down the rear latch, I have to tug pretty hard at the front to get it lined up with the holes. You could try moving the frame + top forward by loosening the bolts that hold the frame down, while also moving the rear latch. Others may be more experienced in this department!
Final tip: I noticed that between the canvas and the folding part of the metal frame that meets the top of the side windows (I hope you are still with me) there was a gap that I could see straight through (about a half inch in the middle, where the gap was the widest). I noticed the same on other Pagodas. What I did to remedy this (lots of wind noise at speed) is I cut strips of self-adhesive black insulation foam, about 3/4 inch thick) that I glued onto the top of the metal frame; now when the top is up, the foam seals the gaps and no more wind noise! (which makes for more comfortable driving longer distances). I will try to remember to take some photos next time I'm at the garage.
« Last Edit: September 29, 2004, 14:16:38 by cees klumper »
1972 Lancia Fulvia Coupe 1.3
« Reply #2 on: September 29, 2004, 14:51:20 »
If I may add to the questions here, it seems I remember Cees had a tip for keeping the soft top from riding up on the corners (see attachment) which I've always thought hurt a 113's appearance. Cees, can you or others give a detailed response to eliminating this common occurence?
Download Attachment: Ragtop1.jpg
43.97 KB
1964 356C
« Reply #3 on: September 29, 2004, 15:00:20 »
Hi Ed. Actually getting the corners to stay down is fairly simple. As you are putting the top down, have a close look at how the corners get folded in, into the soft-top well; there is a small ridge in the well that forces the corners UP. Not a smart place for those ridges, but from memory they could be necessary to accomodate the tires or some other part of the car's sub-structure.
Anyway, what you want to do is fold the canvas DOWN with your fingers as the top is reclining into the well, on both sides. You fold the material underneath the frame as it's going into the well. Richard Madison mentioned that he made 'shoe horns' out of some sort of plastic to make this process easier (it can be hard on your knuckles - but it's worth it).
I learnt this tip off the Yahoo! site about three years ago. After years of having the edges curled up, after only one week in the well folded down this way, the corners 'behaved' perfectly and fit nice and snug to the car body.
« Reply #4 on: September 29, 2004, 19:09:02 »
Cees, I am testing your theory ;) .  A few days ago after reading one of your posts I decided to try it myself.  I wonder if Richard Madison  would post a picture of his "shoe horn" tool :?:   I also have plastic covers on my springs made from an oil container.  :D
CraigD
  • USA, WA, Lake Tapps, WA
« Reply #5 on: September 29, 2004, 21:47:21 »
Message Preview
Not a frame question, but another question on the canvas...
Do you all leave your soft top folded in the well for long periods? I've had the soft top put away for some time now, preferring the top-down mode (or when a top is needed, the lines of the hard top) Does it crease, or become hard to open and latch if folded for months?
Craig in Bellevue, WA
Silver '70 280SL Euro 4sp
Craig
'70 280SL Euro
'55 300S Roadster
'29 Franklin Speedster
'37 Cord S/C Cabriolet (RHD)
« Reply #6 on: September 29, 2004, 22:01:58 »
Craig - the longest I've had my softtop down is about 9 months. I always keep it on the car when I put the hardtop on for the winter which, in Holland, is most of the year [:0].
One precaution I suppose everyone knows (but still) is to never put the top down when wet or damp. Some put a towel on the plastic window to prevent it from scratching (due to the movement that occurs when driving - if there's sand on the plastic the rubbing will cause scratches). One thing to do at least once a year is aplplying some special plastic cleaner (I use Meguiar's which is very good) to the window, which should keep it in like-new appearance. For the fabric, I use Wolfstein's RaggTop cleaner and protectant once a year, which does a very nice job.
« Reply #7 on: September 30, 2004, 07:15:07 »
Nice maintenance routine, Cees. Thanks for sharing. I really like the look of the car with the hardtop on. They certainly didn't nickname this car 'Pagoda' based on it's appearance as a soft top!
Since I am yet to actually take possession of mine, I can only try to envision how often I may use the soft top vs. hard top but know I am going to thoroughly enjoy it regardless of what is or isn't over my head.
1964 356C
« Reply #8 on: September 30, 2004, 07:35:09 »
All good tips !
Wasn't Richards "shoe horn" to be used at the sides to prevent chafing
of the soft top as you lower it into the well !
Also Hauser can you elaborate on the "spring covers".
One thing I did to prevent the glas being scratched is to glue a piece of suitable soft carpet onto the forward verticle part of the soft top compartment, i.e the rear part of where your back would be if you sat into the back area!
BTW I also noticed the gap like Cees, over the side windows, and did the same thing........big difference!
'03 CLK Kompressor
erickmarciano
  • Canada, Quebec, montreal
« Reply #9 on: September 30, 2004, 08:01:57 »
when I put my soft top down I have to open the L shape blacket by hand one one side or it will not go down ,how can I adjust the roof so I do not have to do this
thanks
Erick
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
« Reply #10 on: September 30, 2004, 09:40:01 »
Here's a helpful hint for lifting the soft top out of its compartment.  Make a strap to go around the soft top unit.  You can use an old belt or some type of nylon webbing material.  By doing this your chances of getting the lower portion of the frame are eliminated.
« Reply #11 on: September 30, 2004, 09:51:10 »
Erick,
If I understand you correctly, you're saying that the rear part of your soft top sticks. If you're talking about the rear window. that's a good thing. If you lose tension in the frame there, it's a disaster.
erickmarciano
« Reply #12 on: September 30, 2004, 09:57:48 »
actualy when I put the soft top down there is a L shape bracket I have to move it to the side to put the soft top down .
 usualy the soft top moves this bracket automaticly as it goes down .not in my case
thanks
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
gwuisman
  • Keep it simpel
« Reply #13 on: September 30, 2004, 14:41:44 »
I had this tug problem of Cees to. So I changed the sequence of connection of the front and the rear. Perhaps I'm doing the procedure wrong now but I have no problems getting the front lined up with the holes by first fixing the front and then latch the rear with one strong movement. After some readjusting last winter it goes rather smooth now.
Gerard Wuisman
1970 280sl
« Reply #14 on: September 30, 2004, 15:41:33 »
That's the correct sequence.
« Reply #15 on: October 01, 2004, 04:57:25 »
......not according to my 230SL handbook. It says latch the back first then the front. This is what I have always done with zero problems.....
....I can put the top up, latch it, and be back driving the car in under 20 seconds !
'03 CLK Kompressor
graphic66
« Reply #16 on: October 01, 2004, 07:04:33 »
I believe the 230SL has different instructions than the 280SL. The 230 book does say latch the back first, however the 280 book says front first. My 230SL only will work by latching the back first as it just wont catch in the back latch easily the other way. Does anyone know why the method changes from 230 to 280 model?
« Reply #17 on: October 01, 2004, 08:09:37 »
......Mmm no but there must be some difference to the mechanism or could it simply be that you are less likely to damage the padded header area of the later cars ?  No there has to be more to it than that............did the rear bow position change ?
'03 CLK Kompressor
Joe
  • USA, CO, Colorado Springs
« Reply #18 on: October 01, 2004, 08:21:07 »
I was glad to see this topic come up because my soft top frame is apparently "worn". When I posted about inadvertently dropping the lower bow into the cavity, and having the top stuck up, it was pointed out this is a sign of a worn frame. So far, no one has posted how to avoid having the frame become worn to this extent. Also, I'd be interested in whether replacing the worn parts, whatever they are, is something the average DIYer can do.
Joe2
« Reply #19 on: October 01, 2004, 09:49:22 »
And I like to remind all 'Tight Top' owners that the black box in the center rear of the soft top compartment can be moved up to get the hook a little closer to the top...after I moved the box, locking the top  became a lot easier...
Richard M
andy
« Reply #20 on: October 01, 2004, 11:16:46 »
eric
after the window section is pushed up fully ,if i dont break the top part of the roof, it will  not go back any futher because of these brackets, so it must move something when the top section is broken.cant tell you if this is normall or not.but hope it helps.
andy
spain
gwuisman
  • Keep it simpel
« Reply #21 on: October 01, 2004, 13:42:03 »
My owners manual 280sl says and shows on page 14 that my sequens of closing the top as I yesterday presented is indeed the right one. So Cees for a 280sl the easy way is also the right one.
Gerard Wuisman
1970 280sl
« Last Edit: October 01, 2004, 13:47:13 by gwuisman »
« Reply #22 on: October 01, 2004, 21:20:40 »
Hauser,
If your soft top will not lift out easily and completely, it is because your mechanism is broken.  A fully operating system allows one to lift the front of the softop without the rear portion to be left behind.
Don
« Reply #23 on: October 01, 2004, 21:25:16 »
Thanks Richard,
That's a good tip.
Best regards,
Don
Richard M
« Reply #24 on: October 01, 2004, 21:27:32 »
thanks
1971 280sl
Erick,
Not sure what L-shaped bracket you are speaking of.  Can you post a digital pic?
