Author Topic: Can't identify can attached to bracket under drivers dash  (Read 3056 times)
jerrycastillo
I would appreciate if someone can identify the little can attached to the bracket under the driver's side dash is. It is attached together with the blinker can. Photo attached. It is IWS and has number 500360 12V
Thank you!!
Gerardo
1970 280SL horizon blue
Re: Can't identify can attached to bracket under drivers dash
« Reply #1 on: June 15, 2015, 08:15:04 »
'Key in Ignition' Buzzer?
jerrycastillo
« Reply #2 on: June 20, 2015, 17:45:24 »
Thank you Naj!! You were right! it is the buzzer.
Gerardo
