I'm having a little problem removing the injectors for cleaning from my W112.015. I have removed the center allen bolt and the retaining block. At that point I can move the injectors around but the will only come out a little and are clearly hitting on things. So I removed the two allen bolts on either side of the block in which the injectors are resting. Now the block and the injectors move more freely, but I still don't have enough clearance to remove them. My best guess is that now I should remove the valve cover, since that is where everything is hitting. Is that correct? Or am I doing this all wrong...
thanks
Scott
