Author Topic: ATE Brake Hose Data.  (Read 3808 times)
« on: June 22, 2015, 12:31:50 »
All my "new" brake hoses are ATE Classic, I guess you'd call them OEM.
Remember this is a 1969 280SL, and there is a difference if you have an early car or Girling brakes.
The two hoses for the front are identical and carry ATE Part number 83.7704-0421.3
Each of those has one male, one female end, length specified as 420mm.
The left rear hose carries part number 83.6104-0220.3 and this has one male and one female end.
The right rear hose carries part number 83.6204-0240.3 and this has two female ends.
Both rear hoses specified as 220mm.
You can find the data on the hoses in the ATE Classic Catalog which is here:
http://www.ate-brakes.com/www/download/ate_de_de/themen/ate_c3_classic_katalog_uv.pdf
(I received a PM on this data and thought it would be useful to post it here)
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
Re: ATE Brake Hose Data.
« Reply #1 on: June 22, 2015, 21:03:28 »
Is it possible that you have the left & right rear part numbers reversed?  Under my car, the left side hose threads directly into the proportional valve and for that reason must be female on both ends.  Not that it would matter.  You couldn't install them incorrectly.
« Reply #2 on: June 23, 2015, 14:29:35 »
Ray, I got the parts from our friend Dave Gallon. I've never known him to make a mistake.
AFTER I received the parts from him, the packages said "ATE Classic" on them, and I decided to research what this was about--and I found the link below, which is the ATE Classic Catalog. The MB parts are on page 136 or 137 as I recall. I then matched up the part numbers on the bag, to those in the catalog to determine L + R, and F + B. That being said I have NOT been under the car yet with these parts...Dave went with his part numbers and cross references, which also involved AutoHauzAZ and his other suppliers. The part numbers on the bags match exactly the catalog numbers.
There's no telling exactly what I'll find when I get underneath the car.
