Author Topic: Transmission case color  (Read 4870 times)
pagodarune
  • Norway, Ostfold, Trogstad
« on: June 22, 2015, 13:13:31 »
While my engine is being rebuilt, I plan to tidy up my transmission (4 speed manual) as well. The transmission case needs to be repainted. Does anyone know the correct color code?
Rune R
1966 230SL
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
Re: Transmission case color
« Reply #1 on: June 22, 2015, 21:31:30 »
I don't have a code, but mine was the same black as the engine block and rear end.
pagodarune
« Reply #2 on: June 23, 2015, 04:31:51 »
I do not believe my transmission has been repainted. The color is grey (with a hint of green). I have seen the same color on several pictures, but I have not been able to find the color code.
Rune R
1966 230SL
« Reply #3 on: July 03, 2015, 23:04:25 »
It looks like army green. The inside of older Benz rims tended to be painted this colour. I imagine there was a lot of cheap green paint around after the war. ;D
RobSirg
« Reply #4 on: June 05, 2017, 20:37:12 »
Guys,
Hope you can help.
I'm hoping to find out the original colour of the case / housing to a 4 speed manual transmission.
Mine also looks to be a pale mist green color.
Can anyone provide any further information on likely paint code / number? (Photo?)
« Last Edit: June 05, 2017, 20:41:14 by RobSirg »
1962 E Type Jag BRG with Tan
1974 White Alfa Spider 2000
2023 Range Rover
1982 280TE (my daily)
1977 Yellow 911 Targa
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
« Reply #5 on: June 06, 2017, 14:14:23 »
As has been tossed around on this site, PPG DPLF 40 epoxy primer is about the same green grey color and has a satin gloss to it which is also correct. It supposedly can be left not top coated although I would check with your auto paint store to be sure. I have used it many times when painting cars and is a top quality primer. Ain't cheap though. As opposed to spraying with a gun, you might try using a Preval sprayer https://store.preval.com/collections/preval-sprayer/products/preval-sprayer?gclid=CPjr9JqzqdQCFQUoaQod0tAD5g You might need to thin a bit more to get a good spray pattern.
RobSirg
« Reply #6 on: June 06, 2017, 22:20:28 »
Thanks Wallace,
This is most helpful
Regards
2023 Range Rover
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
