Author Topic: Electrical wiring of terminal attached to oil pan  (Read 5564 times)
jerrycastillo
« on: June 23, 2015, 12:29:28 »
The wiring of my car has been modified through the years and I am working to revert to original. Have searched the forum for correct wiring of the terminal at the oil pan and found the photo attached but no wiring diagram. I will appreciate if someone could tell me what wire goes where from this terminal (a diagram would be most welcome). Many Thanks!!!
Gerardo
1970 MB 280SL Horizon Blue
WRe
Re: Electrical wiring of terminal attached to oil pan
« Reply #1 on: June 23, 2015, 13:00:41 »
this wiring belongs to the automatic gearbox, see here: www.sl113.org/wiki/Automatic/Start.
...WRe
tel76
« Reply #2 on: June 23, 2015, 19:44:00 »
No, that terminal block on the RHS of the engine is for alternator and starter terminals.
Eric
jerrycastillo
« Reply #3 on: June 23, 2015, 20:37:35 »
Thank you WRe and Eric for your answers.
My car is a manual 4speed trans and it has such a terminal attached to the oil pan. Wires from the alternator and apparently from the battery run to that terminal. I am trying to find out the correct setup at the terminal.
Gerardo
1970 280SL Horizon Blue
Pinder
  • USA, NJ, Edison
« Reply #4 on: September 08, 2015, 01:20:20 »
did you get your problem resolved? i have the exact same block on my manual 1970 and can let you know where the wires run. Its to the alternator.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
Pinder
  • USA, NJ, Edison
« Reply #5 on: September 08, 2015, 01:20:41 »
sorry i mean starter motor.
