Author Topic: Tool quiz  (Read 10297 times)
mbzse
Tool quiz
« on: June 23, 2015, 15:37:11 »
Perhaps some may enjoy a tool quiz. It is a factory workshop item.
What is it (for)?
(perhaps the ones here in our Forum who are a bit "into it" may hold back a little   ;)
/Hans in Sweden
« Last Edit: June 23, 2015, 17:57:23 by mbzse »
/Hans S
Re: Tool quiz
« Reply #1 on: June 23, 2015, 15:49:13 »
Looks like a puller of sorts.  Definitely a puller ???
Re: Tool quiz
« Reply #2 on: June 23, 2015, 16:32:29 »
I don't know whether I qualify as one of the 'into it' people Hans, so I will hold my fire for now ;-)
Re: Tool quiz
« Reply #3 on: June 23, 2015, 17:48:00 »
I have a very similar looking corkscrew. That's a very useful puller
Rolf-Dieter ✝︎
  • Canada, ON, London
Re: Tool quiz
« Reply #4 on: June 23, 2015, 17:59:56 »
hauser is on the right track alright .... Like Cees I will hold my fire too .... James I too have something similar only it has two arms that move up into the air and I use it to open a bottle of my well aged fine red wine every other night or so :)
Nice thread Hans .... Keep on posting ... I recall my master in Germany when I asked him "Do we have a tool to handle this?" He would look over his glasses and in a firm look would say "No ... Make one!"
I look forward to see some of the special tools that have been made and used on our Pagoda's :)
« Last Edit: June 23, 2015, 18:27:29 by Rolf-Dieter »
scoot
  • USA, CA, Altadena
Re: Tool quiz
« Reply #5 on: June 23, 2015, 18:05:33 »
Hmmm.   Does it have anything to do with an injection pump?
Scott Allen
'67 250 SL (early)
Altadena, California
Jowe
Re: Tool quiz
« Reply #6 on: June 23, 2015, 19:02:23 »
BBB 15-18/2: puller for crankshaft sprocket for timing. (Never seen or used it, just browsed)
Johan
tel76
Re: Tool quiz
« Reply #7 on: June 23, 2015, 19:20:26 »
MB Puller for removing the pins that hold the timing chain rails.
Eric
mbzse
Re: Tool quiz
« Reply #8 on: June 23, 2015, 19:42:30 »
Quote from: scoot
Sorry, no. Different area on vehicle.
/Hans in Sweden
/Hans S
mbzse
Re: Tool quiz
« Reply #9 on: June 23, 2015, 20:44:23 »
Quote from: Jowe
Nope, smaller job than that
/Hans in Sweden
/Hans S
mbzse
Re: Tool quiz
« Reply #10 on: June 23, 2015, 20:48:22 »
Quote from: tel76
Very good answer, actually... but - No  :)
I do not know if there is a factory tool for those pins on the engine front(?)
We are getting there. When we have a "bingo" answer, I'll show some pictures of the tool in use
/Hans in Sweden
« Last Edit: June 29, 2015, 21:02:32 by mbzse »
/Hans S
Re: Tool quiz
« Reply #11 on: June 23, 2015, 21:16:03 »
There is a tool for the sliding rail pins.  I have the center bit but have yet to find the 2 other pieces.
mbzse
Re: Tool quiz
« Reply #12 on: June 25, 2015, 18:25:26 »
Ok, anyone then!
What is it (for)?
/Hans in Sweden
/Hans S
Re: Tool quiz
« Reply #13 on: June 25, 2015, 20:25:40 »
The 4mm thread attaches to something and the the part being pulled fits into the cavity of the cylindrical  piece?
mbzse
Re: Tool quiz
« Reply #14 on: June 25, 2015, 20:38:24 »
Quote from: hauser
Certainly so!
One more comment: It is valid for all Pagoda models, except the very early 230SL
/Hans S
Benzo
Re: Tool quiz
« Reply #15 on: June 26, 2015, 13:01:56 »
Does it pull the plunger out of the warm run device if its stuck?
ejboyd5
  • Southold, NY
Re: Tool quiz
« Reply #16 on: June 26, 2015, 13:23:01 »
Not looking at a Pagoda right now, but in other M-Bs of the era it might be used to remove the rotating central core from a heater control valve.
mbzse
Re: Tool quiz
« Reply #17 on: June 26, 2015, 13:40:53 »
Quote from: ejboyd5
.../... it might be used to remove the rotating central core from a heater control valve
Bingo!
That's is just what it is for
Well done, five Stars to yourself, he he  :D
/Hans in Sweden
/Hans S
mbzse
Re: Tool quiz
« Reply #18 on: June 26, 2015, 13:42:51 »
Quote from: Benzo
Hey, not precisely what Mercedes designed it for, but that would be a good use for it!
I'll post some pictures showing the tool in action
/Hans in Sweden
/Hans S
mbzse
Re: Tool quiz solved I
« Reply #19 on: June 26, 2015, 14:23:25 »
Answer to Quiz
This is the M-B official tool for removing a (stuck) heater valve
I was happy to find the item, as they are kind of rare.
The tool has a M-B number 180 589 023 300      This indicates it was introduced in the fifties, to serve the Ponton type cars.
The tool is useful even today, as it ensures that the outer soft brass metal body (housing) of the heater valve, with its horizontal slit,  is not damaged when a stubbornly corroded valve body is extracted.
Enclosed are pictures of how it is used. Shown here on a "free" passenger compartment heater unit, but it is meant to be used for a unit when in a car.
Note:
The early 230SL's came without the circular opening in the firewall, over the heater valve. This design limited any access to the valve, and was subsequently changed. An opening covered by a plastic cap was introduced
« Last Edit: June 26, 2015, 14:37:56 by mbzse »
/Hans S
mbzse
Re: Tool quiz solved II
« Reply #20 on: June 26, 2015, 14:26:03 »
Some more images of the factory tool in use.
The rubber O-ring on the brass valve body must be exchanged prior to re-assembly, use water faucet type grease
O-ring is M-B part 000 835 5898
/Hans in Sweden
« Last Edit: June 26, 2015, 14:55:26 by mbzse »
/Hans S
Re: Tool quiz
« Reply #21 on: June 26, 2015, 22:40:37 »
Wow.  That's obscure.  Wasn't even listed in my 1970 Mercedes tool catalog.
