My kit contained a small container of LocTite, with no explanation. I have no idea what it is for.
The instructions are to test with Diesel first, and then carb cleaner. What he doesn't tell you is how to get the diesel (or carb cleaner or whatever) out of the reservoir to switch fluids. I made a big mess trying to unscrew mine and dump it. Also he has you put a filter in the bottom of the reservoir -- there is no good way to empty it without reaching in and pulling out the filter. Having said that, what worked for me was to clean as much as I wanted (do ALL of the diesel first and then ALL of the carb cleaner -- don't try to switch back and forth because it's just a big mess) I pumped the rest out of the reservoir into a bottle for toxic waste. (without an injector attached). I also bought the 5000 PSI gauge in case I want to use it with diesel injectors.
The biggest problem I had with the tester was getting a good seal between his hose and my injector seat. Very difficult to get it tight enough that there was no leak-down. Don't know if that is a statement about my injectors or his fitting
Regarding the Loctite, I didn't get any in my kit. However, Kent maybe thought it would be useful to seal the threads with. I used own thread tape instead, as he recommends in the video and in the mounting instructions.
When it comes to exchanging the diesel with carb cleaner, I just pumped out as much diesel as possible through the injector and the hose to a closed container. Then, I just topped up with carb cleaner and continued the cleaning process. In fact, I think that the diesel itself made some cleaning work when stroking high pressure. After final stage, I of course needed to empty the container, filter, pump and hose thoroughly.
I didn't have any problems with the hose and the injector seats (R1 injectors). Maybe Kent has supplied with another hose type lately that fits better.
But, as you also assumed, the kit did a good work and I'm quiet satisfied, getting the injectors to a 180-200 psi release pressure and good spray patterns. Both the cold and especially the warm starts are much better and the overall running seems to be more "spiritual" after the treatment. Now the kit is on its way to Canada for another rescue of our beloved cars
