Author Topic: should the clutch arm move freely when you ....  (Read 3122 times)
erickmarciano
  • Canada, Quebec, montreal
« on: September 30, 2004, 21:06:08 »
should the clutch arm move freely back and forth when you remove the slave cylinder?
thanks
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Malc
Re: should the clutch arm move freely when you ....
« Reply #1 on: October 01, 2004, 02:22:32 »
Yes, because it has to move the release bearing!
However do be careful that it doesn't fall off its pivot point! I had this happen to me on another car and only by luck and a lot of swearing I was able to get it back on without taking the box out
Malc
