Author Topic: transmission neutral switch  (Read 3206 times)
piddler
« on: July 04, 2015, 17:56:33 »
My 230 SL will start with the shift lever in any position. There is a cable that runs from the transmission to a lever on the cowl. I am sure that this is the switch for the back-up lights and the neutral safety switch. My problem is that I cannot find the switch on the wiring diagram. The back-up light switch is on there.
 My plan is to try to follow the wire colors to determine which ones go to the switch.
I have a service disc but my new computer will not run it. I will get my old out and try it.
Just wanted to vent.
Re: transmission neutral switch
« Reply #1 on: July 05, 2015, 16:37:51 »
If you take a look at the US version 280 SL diagram it shows that item 48 is the lockout and back up switch. I believe this is item 37 on the 230 SL diagram. Will need a confirmation on this one from the more electrically experienced folks!
