Author Topic: Transmission slip on a 68' 250sl.  (Read 3309 times)
swampfox676
« on: July 11, 2015, 17:38:37 »
Hey all,
    I recently started driving my 250sl after having the engine rebuilt.  When I first drove it, the transmission clunked on 1st and 2nd gear.  Next morning when I tried driving the car, the transmission started slipping out of gear with any acceleration.  My transmission fluid I discovered was low because the fluid was blowing out of the top of the transmission pump.  I replaced the pump wing nut, which gave me a proper seal.  I then refilled the transmission fluid while hot.  Fluid level is wear it should be and my transmission is still slipping. Please help.
Sam
« Last Edit: July 11, 2015, 20:21:07 by swampfox676 »
Re: Transmission slip on a 68' 250sl.
« Reply #1 on: July 12, 2015, 03:36:58 »
Good advice, yes, make sure that the engine is running and the car is on level ground when you check the transmission fluid level.
« Reply #2 on: July 13, 2015, 00:35:24 »
.... because the fluid was blowing out of the top of the transmission pump.
I don't believe there is a "transmission pump".
As "fosdicke" said, you may be dealing with the power steering fluid reservoir.  It has a wing nut on top, is round, and is located near the distributor.
If you're putting transmission fluid in your power steering fluid reservoir, you may be causing other problems.
swampfox676
« Reply #3 on: July 17, 2015, 03:11:15 »
Thanks rwmastel,
      I was putting tranny fluid in the power steering reservoir.  I haven't been able to run the car, but I think you solved my problem.  I'm gonna refill my fluids.  I'll keep you posted.  Thanks again for your help.
Sam
« Reply #4 on: July 17, 2015, 10:16:24 »
Quote
Not at all, they're the same fluid.
