Author Topic: fuel pump fuse  (Read 2492 times)
fuel pump fuse
« on: October 01, 2004, 13:15:06 »
No power to fuel pump..where is the fuse for this....I tried the ones under the passanger side and they seem to be ok.
Any help?   280SL 1983
PBK
Re: fuel pump fuse
« Reply #1 on: October 01, 2004, 13:28:22 »
You have a 107 chassis..
 This is the 113  group, and the fuse for that chassis would be # 4, but that will not apply to your chassis..
 I do have the 107 Cd , if that is the case ..
Re: fuel pump fuse
« Reply #2 on: October 01, 2004, 21:16:16 »
Plnol,
The W113 chassis SL series was produced from 1963 to 1971.  As stated, your car is a W107 chassis.  I recommend you try www.mercedesshop.com and use their ShopForum, there is an SL forum.  Lots of skilled and helpful people there.
« Last Edit: October 01, 2004, 21:16:36 by rwmastel »
